First no start, then no fuel pump after sitting three days
Old Jul 24, 2007 | 04:34 PM
Shribe's Avatar
Car: 1988 IROC
Transmission: 700 R4
Axle/Gears: 2.77
After replacing the ignition switch and disarming stupid viper alarm, my mechanic was able to get my car to run again. Now, if it sits the pressure bleeds down and the fuel pump will not engage when the key is turned. It will start like it has a carb on it and then run fine. It starts normal if started every other day. He suggested a manual switch to prime the fuel pump, I want it fixed right. Someone here knows! Please help. Thanks. Eric
Old Jul 24, 2007 | 04:36 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: First no start, then no fuel pump after sitting three days
Check your fuel pump relay and associated wiring.
Old Jul 24, 2007 | 04:39 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
fuel pump relay has been replaced with new GM unit, the mechanic has tested the wiring in many places, which he said has been done before, which makes me think it was a long standing problem. People lie often when they sell cars...
Old Jul 24, 2007 | 08:32 PM
Shribe's Avatar
Car: 1988 IROC
Axle/Gears: 2.77
The real issue now is the fuel pump not energizing after bleeding down. Why would it do this?
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
theshackle
Mar 5, 2017 06:37 PM
justin57
Aug 20, 2015 07:05 PM
92camaroJoe
Aug 13, 2015 06:07 AM
