PCV question
Old Jul 24, 2007 | 08:39 PM
onebad89RS's Avatar
Car: 89 RS
Engine: 305 carbed
Axle/Gears: 3.42 auburn posi
PCV question
In the process of changing my valve cover gaskets i broke the breather on the passenger side. so i decided to make my car have 2 pcv valves. started it up. idles good, but i heard a hissing sound coming from my dipstick. pulled it out and felt a good suction on it. pulled out the vacuum guage and it reads 6" HG at the dipstick. I know about the trick of using a vacuum pump, so is this kinda doing the same thing? and my question is will it help or hurt anything on this high mileage motor?
Old Jul 24, 2007 | 08:43 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: PCV question
You don't want 2 PCV valves, you want a PCV valve and a breather.
Old Jul 24, 2007 | 09:05 PM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: PCV question
if you don't have a breather, it will blow the dip stick part of the way out & you'll have oil pump out of the dip stick tube at WOT. if you get the dip stick so it will stay in, you'll start leaking oil from the gaskets & main seals.
1fast91
Sep 8, 2015 01:48 PM
1985chevydude
Aug 20, 2015 12:29 AM
redmaroz
Aug 16, 2015 11:40 PM
