AFR Eliminators - re-torque?
Old Jul 25, 2007 | 07:08 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Do they need to be re-tourqed after a few heat cycles or is it set and forget?
Old Jul 25, 2007 | 08:51 AM
Thomas Aquinas's Avatar
Car: 1986 Iroc
Engine: Afr 408
Transmission: T56 Magnum
Axle/Gears: Moser 9" 3.70s
Re: AFR Eliminators - re-torque?
I don't have the eliminators, just old 195's. They used the same Fel-pro head gasket #1003. Did you use that one? The instructions that came with the head gasket recommended a retorquing after a couple heat cycles. I retorqued mine the same time I replaced the break-in shorty headers for LT's. I would retorque them if you have the means, couldn't hurt.
I can't wait to upgrade to the Eliminators, probably full CNC too....
Old Jul 25, 2007 | 10:30 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I used the 1094 shim gasket.
.015 compressed thickness.
Old Jul 26, 2007 | 08:31 AM
Car: 1986 Iroc
Engine: Afr 408
I'd check the instructions that came with the gasket. Most of the time retorqueing depends on what type of gasket is used.
Old Jul 26, 2007 | 03:42 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
I looked. It states retorqueing is necessary on high compression and forced induction engines. It doesn't define high compression though.
I checked 10 of my head bolts on one head. None moved. I'm going to assume that the rest are fine.
Pac J
May 17, 2020 10:44 AM
ULTM8Z
Oct 2, 2015 01:25 PM
