bad oil pump?maybe
Old Jul 25, 2007 | 09:30 PM
alpine247's Avatar
Car: 1988 IROC-Z
Axle/Gears: 2.77 posi stock
bad oil pump?maybe
ok my car had a knock so i replace the rod bearing last weekend.the last bearing on the crank did spin but didnt do major damage to the crank also didnt have any metal shavings.so i insert grease before i put the new rod bearing in place.got everything back together.i crank it up no knock at all,then after 15 min running time the knock come back slowly.
Old Jul 25, 2007 | 09:51 PM
Re: bad oil pump?maybe
bad oil pump?maybe
Don't bet on it.
no major damage to the crank
What does that mean?
It works like this. Damage: yes/no. Either it was damaged, AT ALL, or it wasn't, AT ALL. "No major damage" is about like "just a little bit pregnant": either you are or you aren't. Period.
Either there actually WERE metal shavings left in the motor, as there virtually ALWAYS are when a bearing trashes itself; and/or the crank was damaged. Either of those things will guarantee an immediate failure of a new bearing shell.
Sorry to be the bearer of bad news, but it sounds like you just wasted some time and gaskets and fluids.
Old Jul 25, 2007 | 10:04 PM
alpine247's Avatar
Car: 1988 IROC-Z
the very last crank journal had light scars in it.and yes there was probably metal shaving still in there.
but what gets me after the grease i put on the rods bearing burn off that when it starting knock again.if the crank journal where worn down it would have started knock when it first crank it right?
toronto formula
Nov 10, 2015 06:17 AM
Wife'sCar
Members Camaros
44
Sep 30, 2015 12:42 PM
Navy8125
Aug 21, 2015 09:32 AM
Winchester1094
Aug 18, 2015 10:23 AM
