head flow hp calculator, what do i enter?
Old Jul 26, 2007 | 08:57 AM
bigchief's Avatar
Car: 1989 Firebird Formula
Engine: 5.7L 355 TPI
Transmission: 700 R4 with TCI rebuild kit and valve body mods
i found this website because i wanted a quick way to see the maximum amount of hp i could make with a set of heads that flow these numbers: 62, 140, 203, 239, 259, 256. heres the website: http://www.bgsoflex.com/flowcalc1.html
its just that i dont see my hp coming up correct, what should i be typing for Test Pressure for CFM Measurement
Old Jul 26, 2007 | 09:54 AM
Re: head flow hp calculator, what do i enter?
Whatever those numbers were obtained using.
In general, with flow numbers at 28 in Hg, the MAXIMUM THEORETICAL HP you can get out of the heads will be about 2 times the flow numbers; or in that case, about 500 HP. The exact amount will depend on all sorts of other things; compression, BSFC, material the heads are cast from, cam properties, exhaust, etc. etc. etc.; but that will give you a rough idea of what to shoot for. Don't believe this "2.165 HP/CFM" type of crap, because there's WAY too many variables. Trying to "calculate" it down to that kind of precision is a "measure with micrometer, mark with chalk, cut with axe" situation.
Old Jul 26, 2007 | 10:39 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
This simplified formula is used and promoted by AFR.
.2575 X cfm@28" X number of cylinders = max hp.
To find how much power you can realistly get at a streetable compression ratio, I use the 90% rule. Multiply the AFR airflow/cfm formula result by .9.
So a head that flows 259cfm should be good for 480hp at a usable 9.5-10:1 compression ratio.
This assumes you have a correctly tuned motor with a big cam, good intake, headers etc.
You may exceed this on a very well built motor by employing all the dirty tricks, but, not by much.
gta90
Sep 15, 2015 04:00 PM
Mickeyruder
Sep 2, 2015 02:45 PM
fasteddi
Sep 2, 2015 10:29 AM
yankeecarman
Convertibles
Aug 23, 2015 07:47 AM
theurge
Aug 21, 2015 12:46 PM
