Idle
Old Jul 28, 2007 | 01:41 PM
blackandgoldl69's Avatar
Car: 1984 camaro z28
Engine: L69 H.O
Idle
I have a 1984 z28 with the 5.0 HO l69 and i was just wondering what the normal operating temp idle is supposed to be mine is 500 rpm and i think it needs to be higher because droppoing that low makes my battery gauge go down but when you barely hit the gas the guage will go back up.
Old Jul 28, 2007 | 05:04 PM
1fastam's Avatar
Car: 1991 transam
Engine: 305 30 over long tubes into 3" y
Axle/Gears: 4:10
Re: Idle
take it up to 700-750 should be fine,later jimmy
Old Jul 28, 2007 | 08:14 PM
customblackbird's Avatar
Car: 87 TA clone
Engine: 70/70 Turbo 5.3 LS
Transmission: bullet proof 2004R
Axle/Gears: ford 8.8, 3.55 gears
Re: Idle
600 should be ok if u wanna bump it up to 650 thats ok. 700/750 is kinda high i think.
i think stock asked for 550/600
Old Jul 29, 2007 | 01:50 AM
ntomsheck's Avatar
Car: 1989 GTA
Engine: 350TPI w/ Speed Density
Axle/Gears: Borg warner 3.27
Re: Idle
comp controlled to 600-650 in drive/reverse. 800-900 in park/neutral is healthy. You'll have to press the gas in lightly for starting if in a cold area.
junior419
Apr 7, 2025 11:35 AM
Grant2k
Apr 4, 2016 08:21 AM
86IROC112
Nov 27, 2015 09:54 AM
Stroopwafel
Sep 11, 2015 06:38 AM
IROCtometal
Sep 9, 2015 10:01 AM
