Fuel Problems??
Old Jul 31, 2007 | 02:25 PM
Camarogurll's Avatar
Fuel Problems??
I have a 88 TPI Camaro 5L. I just replaced the fuel pump (because it wasn't working) and filter, but it's still not working properly. The fuel pressure is 41 PSI, the fuel flow is suppose to be 1/2 a pint in 15 seconds but it's only 1/4 pint in 7 seconds and then stops. It's surging, lurching and stalling. I unplugged the sensor (electrical plug) from the evap. emissions pressure valve which is on top of the evap. emissions canister. Then it worked almost perfect I just got a evap pressure valve from the local junkyard and it didn't change anything.....Does anyone know what the hell is going on?
Old Jul 31, 2007 | 07:03 PM
zacharyhorn's Avatar
Car: 91 Firebird
Engine: Turbo 355
Axle/Gears: 3.73:1 7.625" 10 Bolt
Re: Fuel Problems??
Well, 41 psi sounds about normal. I'm not very familiar with TPI but try replacing the relay, or check your wiring. Also, try connecting a fuel pressure gauge and route it to where you can see it while driving and see what your fuel pressure is doing.
Let us know.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
