Oil Pressure Sending Unit Problems
Old Aug 2, 2007 | 05:29 PM
Rossi's Avatar
Car: '92 Camaro RS
Engine: LO3
So I tried to install a new Oil Pressure Sending Unit today, but had some trouble. The car is a 1992 Camaro RS LO3, so I have the combined switch and gauge above the oil filter.
It definitely wasn't easy to get out, and there wasn't enough room to use the socket made especially for it. I was eventually able to get the original one out using some vice grips.
So I figured that was the hard part and installing the new one would be easy, but for the life of me I can't get it in. I'm not crazy or retarded, but I seriously can't scew the new sending unit in. I even tried putting the old unit back in, but had the same problem. I have it almost perfectly straight, but just can't catch that first thread. Every once and awhile it feels like it catches just a little bit, but then slips. Anyone have any suggestions, because this is turning out to be quite fustrating.
Thanks.
Old Aug 2, 2007 | 06:49 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Oil Pressure Sending Unit Problems
Try carefully chasing the threads with a pipe tap, but be absolutely certain that no metal bits get into the oil passage.
Old Aug 2, 2007 | 07:16 PM
Rossi's Avatar
Car: '92 Camaro RS
Engine: LO3
I don't have a pipe tap, or the know how to do that. I tried to carefully clean out the first thread, but that didn't help. If it comes down to it I will end up towing it to a garage, but I would really rather not.
Edit: Oh and there is almost no room to work with, which was why it was so tough getting it out in the first place.
Old Aug 3, 2007 | 03:26 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
You can get one at your favorite hardware store.
Old Aug 4, 2007 | 09:03 PM
FYRCHKN's Avatar
Car: 1988 SC Convertible
Engine: LT-1
Axle/Gears: 3.23 posi w/PBR's
I had the same problem when I replaced mine. I tried for at least an hour or two to get it back in, but it felt like it would cross thread after the first turn. I felt really stupid when I figured out I was trying to screw it into the wrong hole. There's a threaded opening in the block (the same size as the hole for the sending unit) right above where the sending unit goes. Not being able to see what I was doing, I was trying to screw it in there instead of the hole that it goes in.
Old Aug 5, 2007 | 04:20 AM
Rossi's Avatar
Car: '92 Camaro RS
Engine: LO3
Man I hope thats it. I tried for about as long as you did, at least 2 hours, and had someone else try as well. I got my head as far up in there as possible to try and look in that hole, and didn't see another one, but I seriously hope thats it.
I will try again tommorrow, cause the car isn't parked at my house, and let you guys know. I really appreciate the help though, no matter what the outcome is.
Old Aug 5, 2007 | 04:22 AM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
There are two holes. One for the oil passage, and one for the mechanical clutch linkage.
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
89GTAOz
May 16, 2020 09:31 AM
Infested
May 22, 2018 11:56 PM
db057
Aug 22, 2015 08:17 PM
