Hood Won't shut, really need help
Old Aug 5, 2007 | 08:56 PM
jyoung86's Avatar
Car: 1987 Trans Am
Engine: zz4 350
Axle/Gears: 2:73
Alright, I did a build up on my 87 trans am. Everything is put back together go to strap the air cleaner on the carborator but there is one problem. The hood hood just barely won't close. The Front of the air filter is hitting the hood and keeping it from shutting. I don't know what to do, I tried a low profile one but the front end of the round disk keeps hitting. Does anyone have a solution that won't restrict the power and doesn't require modding/changing the hood? I really could use the help.
Old Aug 5, 2007 | 09:01 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Hood Won't shut, really need help
on the air cleaner base there is a ridge that could be ground off for maybe 1/2 inch of drop if you have room for it
Old Aug 6, 2007 | 05:45 AM
JamesC's Avatar
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
If you're using a 15 x 3" filter swap to a 14 x 3" (or you could go to a 2 1/2). Either way, as Spito suggests, a 1/2 drop base will probably do the trick.
JamesC
Hotrodboba400
Dec 10, 2019 07:07 PM
Fronzizzle
Sep 8, 2015 12:10 PM
Randomtask2
Sep 7, 2015 05:06 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
SlowAZ28
Sep 2, 2015 05:19 AM
