87' IROC posi?
Old Aug 5, 2007 | 10:42 PM
kdxrider9262's Avatar
Car: 1987 IROC-Z Camaro
87' IROC posi?
I've been told that my iroc z-28 has posi, however when leaving my mark in various places, sometimes its two tires and sometimes its one? Does the rear end need a fluid change or is it just not posi? The car sat for well over a year and a half........check my garage for more info....
Thanks,
Steve
Old Aug 5, 2007 | 10:45 PM
Bandit4142's Avatar
Re: 87' IROC posi?
Its possible that the diff isn't fully locking due to its age, or wear of components. In either event, you can jack up the rear end suspending both rear tires, turn one of the axles... if the tires move in the same direction, its a posi, if they turn in opposite directions, then its an open rear.
At least I think that theory works on modern posi diffs.
Oh, and obviously the car needs to be in neutral.
Old Aug 5, 2007 | 10:58 PM
Re: 87' IROC posi?
thanks....I gott fix the heater hose I blew then Ill let you know
Old Aug 5, 2007 | 11:14 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: 87' IROC posi?
okay it is easy to tell... inside the center console there is an RPO sheet a bunch of alpha-numeric combos of 3 look for G80 that is for posi and a GU3 or GU4 for the gear ratio either 3.08 or 3.27 you can also look at the diff cover there should be a tag that says BorgWarner or a tag that says use posi fluid or something to that effect
Old Aug 6, 2007 | 02:18 PM
Re: 87' IROC posi?
well....I couldn't find that sheet you were talking about so I crawled underneath and it said "Use Limited Slip Diff Fluid Only"
Old Aug 6, 2007 | 02:37 PM
Re: 87' IROC posi?
I'll give the same answer as all the rest of the incessant redundant "do I have posi" threads on the forums. That REALLY REALLY should be a sticky, so that maybe people will know to not ask that and instead go do the research.
The ONLY WAY to know for sure what's inside your rear end, is to take off the cover and look. Everything else - codes, tags, stripes, spin-the-wheel, ALL OF IT - is nothing but guesswork. Some might be better-educated guesses than others, but all are still guesses just the same. In a 20-year-old performance car, there's NO GUARANTEE that whatever rear end came in the car, or whatever parts came in the the rear end housing that's currently in it, is what came in it.
Have you changed the fluid lately? I suspected as much.... so while you're catching up on the overdue basic maintenance and you have the cover off anyway, make a point of looking in the carrier and see if there's springs and clutches in there, or basically, anything besides a shaft and some gears. If there's anything else, then it IS posi, and you do indeed need to add the limited-slip (posi) additive.
And to avoid yet another incessant redundant post, "what gear ratio do I have", look at your gears as well while you're in there. Find the stamping around the edge of them, or count the teeth if you can't find the stamping.
Old Aug 6, 2007 | 03:26 PM
Re: 87' IROC posi?
Well.......your help is greatly appreciated and I am the second owner and the car has 64k orig miles.......sticky would be nice
hectre13
Dec 11, 2023 08:14 AM
hectre13
Aug 26, 2015 08:17 AM
mcgarnicle
Aug 12, 2015 04:58 PM
mustangman65_79
Aug 11, 2015 03:17 PM
