Advantages and Disadvantages. 52psi
Old Aug 7, 2007 | 09:09 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
What are the advantages and disadvantages of running 52 psi fuel? I know that's high but the only way I can get it lower is if I remove the plenum and grind even more out of underside.
Could I lie to the computer and tell it I have 37 or 38 pound injectors instead of the 36 it thinks I have now?
This is in regards to the 92.
Old Aug 7, 2007 | 11:06 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
Shortened injector and pump life.
Old Aug 7, 2007 | 11:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Re: Advantages and Disadvantages. 52psi
Can you explain the shortened pump life part? Why would it shorten the pump life? The pump pumps around 80psi regardless of what pressure you're allowing through the rail.
Not trying to be argumentative, I actually want to understand this.
Old Aug 7, 2007 | 11:26 AM
five7kid's Avatar
The pump puts out the pressure you regulate it to. The higher the pressure, the harder you're working it. Pressure is regulated by controlling the return - the higher the pressure, the less the return.
If you dead-head the pump, outlet pressure will probably be in the neighborhood of 80 psi, and its life will be very short. The higher you are from stock, the closer you are to dead-heading it, so the shorter the life.
Old Aug 7, 2007 | 12:02 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Okay. Thanks.
djmarch
Oct 2, 2015 10:41 PM
age
Aftermarket Product Review
Dec 5, 2001 06:20 PM
mostafa3k
Mar 19, 2001 10:40 PM
e-man
Nov 12, 2000 08:17 PM
496Monte
Jul 24, 2000 10:03 AM
