more posi help needed
Old Aug 7, 2007 | 10:52 AM
spina74's Avatar
Car: 01 Trans Am Ws6, 92 Camaro Rs
Engine: 6.0, 305
Transmission: T56,700R4
Axle/Gears: 3.90 9", 2.73 10 bolt
OK, i finally got the unit out and thanks everyone for all your input on that, it popped right out when I used the pry-bar. Now my new problem is that I pulled the unit out and didn't unbolt the pinion . So i tried to put the unit back in so i can use the e-brake to keep the posi from spinning but i can't keep the F**KING shims to stay in the housing. I was thinkin cleaning it up and using some pray glue to hold them in or if anyone knows how to unbolt the pinion w/o it turning I tried to jam a prybar in the yoke(or w/e its called) to keep it from spinning but all that does it put pressure on the socket and make it not turn. Im racking my brains out considering this is the first time i've ever worked on a rear.
Old Aug 7, 2007 | 02:17 PM
Re: more posi help needed
See a picture of my "special tool" here (no, it's one that you can let your kids look at too...)
https://www.thirdgen.org/forums/tran...t-my-rear.html
Old Aug 7, 2007 | 03:42 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Mine was an old lawn mower blade with the edges ground dull.
Old Aug 7, 2007 | 11:00 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Mine is a 4' long piece of 1/8" x 1"x1" angle iron. I have the rear end up on those cheapy $20 plastic sawhorses, then put my foot on the end of the angle iron and reef on that nut.
Remember, replace the nut with a new one, and use a cold chisel (or red loctite) to lock it in place after.
Let me know how you get the shims all back in. I'm trying to figure out a source for a shim-installer gizmo.
hectre13
Dec 11, 2023 08:14 AM
IROCZ1989
Jan 24, 2016 03:55 PM
kitt23
Exterior Parts Wanted
Aug 15, 2015 12:37 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
