High Idle Problem Fixed
Old Aug 7, 2007 | 11:28 AM
Blue_Thunder's Avatar
Car: 1986 Chevy Iroc-Z28
Engine: 1989 TPI 350
Axle/Gears: stock 10 bolt with 2.73 gears
It was my ECM that was bad. The scantool was saying that there was no tps voltage and the wires to the sensor were good. I tested the TPS by removing it and putting on a new one. That still didn't fix the problem. I replaced my ECM and That fixed the Problem
Old Aug 10, 2007 | 09:50 PM
Dean_GTA's Avatar
Car: 1988 TA GTA
Engine: L98 Replaced w/ 350/330HP W/TPI
Transmission: Stock 700r4
Axle/Gears: stock 3:27
Re: High Idle Problem Fixed
Hi, when the car was at high idle, was it running rich?
Old Aug 11, 2007 | 05:47 PM
It still runs a little rough, but I was getting around 13-15 mpg in the city when it was idling high.
Infested
May 22, 2018 11:56 PM
Spyder_TheGamer
Dec 25, 2015 05:07 PM
db057
Aug 22, 2015 08:17 PM
zeitghaist
Aug 18, 2015 07:33 AM
