Vortec valvetrain????
Old Aug 8, 2007 | 09:36 PM
1983sc's Avatar
Car: 00' rcsb
Engine: Little boosted 5.3
Transmission: 4l80e
Ok just got a set of vortecs for almost free. My power goel is around 450 HP and close to the same TQ numbers. What cam will match up good with these heads, will have them ported and polished, bigger springs. ect... and also what size rockers should i run? 1.5, 1.6? would i need to get the heads cut for bigger valves to make this kind of power?
any help is much appreciated.
Colt
Old Aug 8, 2007 | 09:38 PM
1989GTATransAm's Avatar
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
Re: Vortec valvetrain????
As was in another post read this link. It will answer a lot of your questions.
http://www.nastyz28.com/forum/showthread.php?t=56505
Old Aug 8, 2007 | 10:00 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i would say the XE 274 if you are planning on a flat tappet cam or the XR270 for a roller... you would be around 420 Fwhp with 10:1+CR
Old Aug 8, 2007 | 10:07 PM
xpndbl3's Avatar
Car: 1984 Z28
Engine: SLOW carbed ls
Axle/Gears: moser 9" 4.11
bigger than XE274, more compression, single plane intake, big carb, big stall, big rear gear
Old Aug 9, 2007 | 12:22 PM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
http://store.summitracing.com/partde...CCA-CL12-568-4
would this be a good cam to run? i am planning on big stall and rear gears.
Old Aug 9, 2007 | 03:34 PM
Car: 91 RS
Engine: 350 vortec
that is better than the 274 but you have to ask yourself... how high do you want to spin this thing to make power? what are you gonna do with it after you have built it?
Old Aug 10, 2007 | 02:10 PM
1983sc's Avatar
Car: 00' rcsb
Transmission: 4l80e
I only plan on going to 6000 RPM i dont want to puch it further then that. this will be a serious street/ strip car that will see more track racing time then it will street time.
69GTOby
Apr 18, 2016 02:34 PM
Quzyle
Oct 15, 2015 03:35 PM
Zell1luk
Sep 29, 2015 10:36 AM
monte87cortez
Sep 26, 2015 08:10 PM
BLK87Z
Sep 18, 2015 11:29 PM
