434 any suggestions for heads and fuel inject?
Old Aug 10, 2007 | 03:03 AM
crazycrocket's Avatar
Car: 1985 camaro
I currently have my 400 block at an engine shop so it can be notched and the rotating assembly ordered in to make it a 434.. does anyone have any suggestions as to what heads and fuel inject setup to run... I am looking to buy next summer and only wanna spend 4 grand on the heads and fuel inject.
427 smallbock bored 30 over
427 and camaro sound good together
Old Aug 10, 2007 | 04:00 AM
5678TA's Avatar
Car: 1984 Trans Am
Engine: broken 385sbc
Transmission: G-Force rebuilt T-5
Axle/Gears: Currie 9" Ford 4.30:1
Re: 434 any suggestions for heads and fuel inject?
i've heard that the 434's eat up ring sets in a year.. so you have to re-ring each year of use.. IMO, i would have just built a 421.. its a 3.875" stroke compared to the 4" of the 434.. but thats just me..
a 434 will need a HUGE runner.. minumum CNC'd AFR 227's.. flow in the 320+cfm range.. EFI is chinese to me.. throw a super victor on it with a dominator 1050..
Old Aug 10, 2007 | 01:53 PM
88305tpiT/A's Avatar
Car: 2016 Ram 1500
Engine: 3.0L Diesel
Transmission: 8sp
Depends on how much power you want to make and how high you will rev it.
First figure that out, Then pick a cam, Then pick the heads. Somewhere in there you should be calculating your dynamic compression so that you can still run pump gas but I assume you know that or you wouldent be asking about "what heads to get for my 434 SBC".
Fuel injection is a question best answered by asking yourself - Do I want to (Can I) tune it or do I want someone else to do it. Answer that and you should have your answer as to what kind of injection you should get.
midge54
Dec 27, 2019 04:14 PM
9192camaro
16
Feb 3, 2019 12:21 AM
84z96L31vortec
Aug 20, 2017 12:16 AM
86Base
Aug 13, 2015 05:06 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
