car runs realy bad
Old Aug 13, 2007 | 09:00 AM
camaro91boy's Avatar
Car: 95 z28 camaro or 92 k5 Blazer
Engine: LT-1 fo the Z. vortec fo K-5
Transmission: 4L60E=Z junkR4=K-5
Axle/Gears: 3.43=Z / 3.73=Blazer
car runs realy bad
help somebody.
a fe
w days ago a hole in the lower radiator hose decided to leak out all of my antifreeze, the car then died in an intersection and when it did it sounded like a diesle after you shut it off. when i looked under the car i found a sensor melted off and hanging by the starter i later found out that it came from a sensor above the knock sensro but the plugs look the same. since then it runs like crap. acceleration is bad feels low on power and just has this real bad rattle to it that stops when i step on the trottle.
any ideas of what the sensor i melted is or how to fix my problem would be helpful.
oh the sensor is on the passenger side and is between the last two exhaust pipes coming off of the mantifold under the heat sheilding.
Old Aug 13, 2007 | 09:16 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: car runs realy bad
Coolant temp sensor
Did you overheat the car?
Old Aug 13, 2007 | 09:27 AM
yeah the gauge ran all the way over. i thought i was bad i just changed the radiator aand both hoses. and since the water pump but the noise still is there and the car still runs like crap.
Old Aug 13, 2007 | 02:32 PM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
You coulda roached your heads or even the shortblock. Hard to do with iron heads but possible.
Old Aug 13, 2007 | 07:22 PM
uhoh i have aluminum heads. but the noise went away when i added some oil. its at shop now being looked at thanks for your imput
86IROC112
Aug 17, 2015 02:00 PM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
Kaweh
Aug 9, 2015 02:54 PM
1992 Trans Am
Aug 8, 2015 08:16 PM
