MAF/Other
Old Aug 17, 2007 | 10:02 AM
scarello's Avatar
Car: 1991 Camaro RS Convertible
Engine: 305ci
Transmission: 4-Speed Auto
MAF/Other
Hi All.
I have an 88 Firebird and I am looking for the more info/location for/of the following:
Mass Air Flow Sensor
Sensor on Passenger side near Firewall (039 1129) with a number 466 on the top and an inline three connector plug and single vacuum line underneath.
Basic problem is when it's cold it idles rough/low and stalls, but when it warms up it at least idles, but still a bit low (Around 500 RPM)
I'm thinking it may be the MAF or even EGR... anyone have any good tests for either?
Thanks in advance
Steve C - RI
Old Aug 17, 2007 | 10:07 AM
scarello's Avatar
Engine: 305ci
Re: MAF/Other
Car runs pretty rich as well; more so when it's cold. Not as much when it warms up.
Steve C - RI
Originally Posted by scarello
Hi All.
Thanks in advance
Steve C - RI
Old Aug 17, 2007 | 11:56 AM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
Re: MAF/Other
You are describing a MAP sensor, not a MAF sensor. A mass airflow sensor would be in the duct between the air filter and throttle body.
The later cars use a speed density system with a MAP (manifold absolute pressure) sensor instead of a maf sensor.
Old Aug 17, 2007 | 12:44 PM
scarello's Avatar
Engine: 305ci
Re: MAF/Other
When I unplug the MAP Sensor, the car idles fine.
Can I assume the MAP Sensor is bad?
If so, can I drive it with it unplugged (Leave Vacuum Line plugged in) or would that be bad?
Steve C - RI
Old Aug 17, 2007 | 01:05 PM
Toehead's Avatar
Re: MAF/Other
https://www.thirdgen.org/forums/tech...ing+MAP+sensor
Replace it as soon as you can. With it unplugged the car will run in alpha-n mode, where it bases fueling solely on RPM and throttle position.
