testing an AIR / A.I.R. pump
Old Aug 18, 2007 | 07:34 PM
91L98Z28's Avatar
Car: Z28
how much air should the smog/AIR pump be able to move when tested per the factory procedures?
The service manual simply says air should be present at the outlet, but ... how much? should it be able to blow your finger off the port? is it just a gentle breeze that you can easily plug with your thumb?
Old Aug 19, 2007 | 02:58 AM
DENN_SHAH's Avatar
Car: 83 POS monte carlo 2015 chevy P/U
Engine: 92 5.7 tpi 5.3
Transmission: 700r4 6L60E
Axle/Gears: 2.42 too high
Re: testing an AIR / A.I.R. pump
they don't build much pressure, maybe 5 PSI.
at idle you should be able to feel the air from it about 2~3 inches away from the output hose. when you rev it, both the pressure & volume goes up, but its still not a lot of pressure.
Old Aug 19, 2007 | 08:09 AM
Right; they are designed to move a large volume of air, at relatively low pressure.
In fact, aquarium stores, where they have those millions of giant aquariums bubbling profusely away in a way you can't ever seem to duplicate at home, often use an AIR pump and a small electric motor mounted on a piece of plywood, as their air source. One such rig can air a surprising number of aquariums.
eightsixseven
Dec 16, 2024 01:50 PM
Jae992
Aug 27, 2015 09:07 AM
theurge
Aug 21, 2015 12:46 PM
Dialed_In
Aug 20, 2015 01:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
