retro-fit roller sbc ?
Old Aug 22, 2007 | 09:48 AM
slow_roc's Avatar
Car: 86 iroc
Engine: sbc
ok i have 73 sbc and the retro-fit sbc hyd roller lifters, i was wondering if i could run a factory roller sbc cam and just use a cam button and trust bearing with the newer style timing set ? to make up for the area were the normal lock plate would go ?
thanks steve
Old Aug 22, 2007 | 09:55 AM
Re: retro-fit roller sbc ?
No... a thrust bearing is MUCH too thick.
You could however, take a factory retainer plate, and grind the "ears" off of it, and use that as the spacer; and of course a cam button. You'd have to use the nylon type of cam button, and trim it WAY down, to fit inside the very small bolt pattern on the front of a factory roller cam.
KO1
16
Oct 15, 2015 05:00 PM
Agent507943
Firebirds Wanted
Oct 2, 2015 07:18 AM
Agent507943
Camaros Wanted
Oct 2, 2015 07:17 AM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
