best way to build a 377
Old Aug 22, 2007 | 03:31 PM
ajl'86T/A's Avatar
Car: 1986 T/A
Engine: 5.0 carb
Transmission: 700-R
I guess the question im really asking is which is the more determining factor in making power, bore or stroke? i have heard that a 4" bore is better because it is the best comprimise between having enough room for large valves and it is still small enough to get good fuel atomization to discourage detonation, which also means it gets better milage. so technically a 350 block with a 400 crank would be better right? does anyone believe for this reason a 377 may make the same or slightly more power than a 400 with the same parts despite the 400 having larger displacment?
Old Aug 22, 2007 | 03:43 PM
Guest
Guest
Posts: n/a
Re: best way to build a 377
That'd be the day.
Old Aug 22, 2007 | 04:34 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Not for that, or any other reason.
Old Aug 22, 2007 | 04:41 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's kind of like the answer to the old question, "How can you have a million dollars investing in the stock market?"
"Start off with two million."
Old Aug 22, 2007 | 05:55 PM
DIGGLER's Avatar
377 is the biggest waste of time ever, imo. people keep wanting to do them, however. you can make more power with a 383 or 400, provided the heads/cam are the right ones for the engine.
Old Aug 22, 2007 | 06:09 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
The 377 he's talking about is really a 383.
ZEEYAA
Apr 16, 2023 08:29 PM
racereese
Oct 3, 2015 03:46 PM
92projectcamaro
Sep 29, 2015 07:07 PM
Zell1luk
Sep 29, 2015 10:36 AM
Jlanz55
Sep 29, 2015 08:55 AM
