Have a lot pressure in gas tank?? Check this.
Old Aug 24, 2007 | 05:25 PM
xlwhellraiser's Avatar
Car: 1992 Trans/am convertible
Axle/Gears: 2.73 drum WS6
Well, after replacing every single component in my evap system, moving the exhaust and muffler (all cost money) I found what the problem was.
Have you guys ever checked into this guy???
Yup, this was the only valve i haven't replaced because I thought they never go bad.
Well, the only way I really found out was after it started Buzzing. Yup, you hear right. The thing was humming like a little biotch.
So, I replaced it with one from the JY and my tank does not build nearly as much pressure as it used to.
I think this is worth replacing if you exhausted all of your options.
Just a heads up.
Old Aug 24, 2007 | 05:35 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Have a lot pressure in gas tank?? Check this.
There was a TSB on those, if i recall correctly.
Old Aug 25, 2007 | 01:04 PM
TSB?? Sorry don't know what that means.
Old Aug 25, 2007 | 03:18 PM
Cat59's Avatar
Car: '87 IROC Z w/43,000 miles
Engine: 305 F code motor
Transmission: 4 speed auto
TSB = Technical Service Bulletins I believe. GM's "smart talk"
Infested
May 22, 2018 11:56 PM
Andrew6.688
Dec 13, 2015 10:59 AM
mustangman65_79
Sep 1, 2015 03:51 PM
AkDrifted
Aug 17, 2015 07:45 PM
kyleb24
Aug 15, 2015 08:24 AM
