recommend heads?
Old Aug 26, 2007 | 08:12 AM
Manic Z's Avatar
Car: 1985 Camaro IROC-Z
Transmission: GForce T-5
Axle/Gears: 10 bolt 3.73 posi
recommend heads?
hello.
Can someone recommend some heads for this engine?
Cam: 218 224 .462 .477 112
Displacement: 355
Rear gear: 3.36
Auto tranny stock stall.
Headers and true dual exhaust.
Approx 9.5 - 1 compression
Dual plane intake.
Qjet carb - no computer
I'm looking for a head available with straight plugs, various combustion chamber volumes (to calculate compression), under $1000, and under 200cc intake volume.
I don't want to use vortecs.
I was considering the dart iron eagle 180cc, but they seem a little soft on intake flow. Any thoughts on these heads? Any recommendations?
Thanks.
Old Aug 26, 2007 | 01:43 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: recommend heads?
There arent very many good heads under $1000. Trick Flows and AFR Eliminators are the two best for the money. I think Patriot Heads and Racing Head Service had some, so search for their websites.
nhra-trans-am
Southern California Area
Sep 17, 2015 10:16 PM
gta90
Sep 15, 2015 04:00 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
thefirebirdm@n
Aug 25, 2015 05:21 PM
86White_T/A305
Aug 17, 2015 12:16 AM
