Removing heater core hoses-need advice
Old Aug 26, 2007 | 12:50 PM
HB Z28's Avatar
I am tackling a heater core replacement on my '87 Z/28 and I'm wondering if anyone has any tips for disconnecting the hoses from the heater core on the engine side of the firewall. There seems to be about one whole inch of room between the back of the block (305 TPI) and the firewall and I can't figure out how to get hands, fingers or tools in there to loosen the worm clamps so I can remove the hoses and proceed with the core change. Thanks.
Old Aug 26, 2007 | 12:52 PM
Synful's Avatar
Re: Removing heater core hoses-need advice
my only tip is....keep your hands as dry as possible
you're right there is barely any room. i had to fight it...big time. and with hands drenched in coolant...slippery. not fun.
good luck though
Old Aug 26, 2007 | 12:54 PM
HB Z28's Avatar
Thanks for the reply. Would it be any easier from under the car?
Old Aug 26, 2007 | 12:57 PM
Wheel Spin's Avatar
Car: 89 Formula 350 (x 2)
Axle/Gears: BW 3.27
Snips?
Old Aug 26, 2007 | 12:58 PM
Synful's Avatar
not at all. infact....it'd be infinitely more difficult.
unless your clamps are facing towards there....then maybe. i have no idea why they would be facing down though.
they're just the clamps you loosen/tighten with a philips right?
Old Aug 26, 2007 | 01:12 PM
HB Z28's Avatar
Yes, they are run of the mill clamps, it's twisting them off the old core and slipping them onto the new one that's the problem. I seem to have large hands. Oh well, time to get very scuffed up and scratched.
Old Aug 26, 2007 | 01:47 PM
hgffrank's Avatar
Car: 83 Trans Am
Engine: LT1 350
Transmission: 5 Speed manual
Axle/Gears: 3.73 10bolt till it breaks
Remove the nut on the transmission mount stud, or bolt if aftermarket, then jack up the rear of the transmission as much as you can until it hits the underpan. By doing this, the engine will tilt forward, and hopefully just enough to make your life a bit easier. Even if its only an extra 1/2 inch or an inch. thats alot when you had none to begin with....lol
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
Street Lethal
Aug 14, 2015 08:25 PM
