Timing for a stock l98 tpi ?
Old Aug 26, 2007 | 01:13 PM
86birdman220's Avatar
Car: '87 Camaro irocz
Engine: 5.7 TPI
Axle/Gears: 3.27 limited-slip
what is the factory setting and what does everyone suggest? its a totally stock 5.7 tpi.
also, i get SES light and its really hard to start unless i play with the timing that clears up but i do not know where it SHOULD be.
thank you
Old Aug 26, 2007 | 01:27 PM
GTA Jim's Avatar
Car: 1990 GTA
Engine: 5.7
Transmission: 4L60
Axle/Gears: 3.27 Posi
Re: Timing for a stock l98 tpi ?
The factory base timing is 6 degrees. Make sure you disconnect the 'Set Timing Connector' when setting the base timing.
Some people advance the base timing to 8 degrees, but it's questionable whether there is an advantage to this or not...
Advancing the timing can introduce knock. When the knock sensor detects this, it will retard the timing to compensate and you're back to square one. You really need a scan tool to read the knock counts to see if advancing the base timing over degrees is doing anything.
Vintageracer
Jan 10, 2020 05:33 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
NBrehm
Aug 25, 2015 11:49 PM
marcusaw
Aug 10, 2015 08:13 AM
Thirim
Aug 9, 2015 06:19 PM
