305 White smoke coming from valve cover area.
Old Aug 28, 2007 | 07:48 PM
coldasice's Avatar
Car: 92 Firebird
Engine: 305 TBI
Axle/Gears: 2.72
Hey guys, I've had my 1991 Firebird with the 305 TBI since feburary. It hasn't run much as its more or less of a project car.
I went to start it up yesterday and after a short while I noticed a white smoke coming from the passenger side valve cover. I did install some aftermarkets a while ago and I susspect they may be the problem. I am also thinking it could be the EGR valve. Upon further inspection I noticed most of my vacum lines are cracked and one is missing. I belive its the one on the far right side of the TBI going to the EGR Solenoid.
I really hope this is something simple instead of a warped head or bad piston ring. Hope you guys can give me some suggestions. Thanks.
Old Aug 28, 2007 | 08:46 PM
Red Devil's Avatar
Car: Tree Huggers
Engine: Do Not
Transmission: Appreciate Me.
Re: 305 White smoke coming from valve cover area.
Did you let it get up to operating temp? If No- Likely condensation burning off. If Yes- check your oil for a milkshake. Yes- You have coolant in the oil. No- Leakdown test time.
Vintageracer
Jan 10, 2020 05:33 PM
NBrehm
Aug 25, 2015 11:49 PM
db057
Aug 22, 2015 08:17 PM
Street Lethal
Aug 12, 2015 11:33 AM
mustangman65_79
Aug 8, 2015 01:18 AM
