whats the knock sensor torque?
Old Aug 29, 2007 | 06:58 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i am replacing my knock sensor what is the spec? thanks.
Old Aug 29, 2007 | 08:58 AM
Viprklr's Avatar
Car: 92 GTA/ 00 TA
Engine: 383/350
Transmission: 700R4/T-56
Re: whats the knock sensor torque?
14 lb. ft.
Old Aug 29, 2007 | 11:45 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
i got 5 different answers,but i took the middle (15) and ran with it but thanks.
Old Aug 29, 2007 | 11:49 AM
It's the DRAIN PLUG. As such, it's really not very critical.
The only 2 things you have to look out for are overtorquing it, which will destroy its "mecahnical filtering" and end up making it SUPER-SENSITIVE; and using something on the threads that prevents it from making a good electrical connection to the block.
15 ft-lbs is fine. Really anything from 12 to about 30 is OK; less than that, and it might leak, or past that, there's the risk of ruining it.
92firebirdguy
Sep 1, 2016 07:53 AM
Ragtop Man
Sep 12, 2015 12:23 AM
FormulasOnly
Sep 10, 2015 09:07 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
tgp1990
Sep 4, 2015 06:24 AM
