wont start, no power to coil
Old Aug 29, 2007 | 08:32 PM
themanoncan's Avatar
engine won't start all of the sudden. found there was no spark from distributor to plugs. saw the coil was burntout, so i replaced the tranformer(coil), cap, and rotor. same problem, tested the battery connection, nothing.
any ideas?
i've been having to get rides to school/work for a couple weeks, and it's getting to be rediculous
also checked the fuseblock
Old Aug 29, 2007 | 09:12 PM
RFmaster's Avatar
Car: 75 Beast
Engine: 383 +EBL Flash
Axle/Gears: 4.11 with 33"
Re: wont start, no power to coil
themanoncan
Check the test tach lead - make sure that it is not grounded. Grounding will cause coil to stay energized and quickly burn out.
Check your IGN fuse.
//RF
92camaroJoe
Jul 29, 2023 07:57 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
92camaroJoe
Aug 13, 2015 06:07 AM
L98GTA87
Aug 5, 2015 11:02 PM
