Failed Emissions
Old Aug 31, 2007 | 09:52 PM
johnboy2814's Avatar
Car: 1989 Turbo Trans Am
Engine: Turbo V6
Failed Emissions
Went to get my 89 TTA tested today and it failed. I used the "guaranteed to pass". The car is mostly stock except for 37 LB inj., torque converter and TurboTweak chip.
Reading Limit
HC GPM 1.34 2.25 PASS
CO GPM 30.64 23.74 FAIL
MOX GPM 1.67 3.25 PASS
My plan of attack is to order a TT emissions chip, change oil, lower fuel pressure,new plugs and then re-try. The O2 is a delco and is about 1.5 years old.
I wanted to see if this was good plan before proceeding????
Old Sep 1, 2007 | 08:10 AM
Cflick's Avatar
Car: 87 Suburban 2500
Engine: 455 Wildcat ( somewhat modified ))
Transmission: TH400 ( for now )
Axle/Gears: 4.10 ( for now )
Re: Failed Emissions
High CO is either too rich, a miss, or a bad cat.
Your CO is high enough to suggest something is broken, like the cat, especially if you're not getting a SES light.
A sluggish O2 sensor can cause this, too.
I'd look for a miss, first. Then the O2 sensor, especially if you have a spare, then look hard at the cat.
racereese
Oct 3, 2015 03:46 PM
mcfastestZ28
Oct 1, 2015 11:23 AM
6998poncho
Sep 25, 2015 02:56 PM
