Valvesprings?
Old Sep 3, 2007 | 03:55 AM
JCL91TRANSAM's Avatar
Car: 91 Trans Am
Engine: 355 l98 mini ram
Axle/Gears: stock10 bolt 3:23 gears
Valvesprings?
How do I check to see if I have bad valvespring? I am having some issues with the motor and I was told that this might be one of the problams.
Old Sep 3, 2007 | 05:33 AM
F-BIRD'88's Avatar
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: Valvesprings?
You can remove the valve covers and visually inspect the springs for broken coils.
Bad valve springs will often show up on a manifold vacuum guage as a fluctuating/vibrating guage needle as you rev the motor.
Other than that you have to remove them to test the spring pressure.
Old Sep 3, 2007 | 08:19 AM
Supervisor42's Avatar
Car: 1988 Trans Am GTA
Engine: 350 4BBL
Re: Valvesprings?
Also, I always put the head of a hammer in my hand and use the handle to push open valves that are completely closed.
Helped me locate valve springs that have "gone away" (gone limp).
It will be obvious.
You can then replace the spring without pulling the head.
Limp springs will not usually show up on a compression test but will show up on a vacuum gauge.
mrestrictrplate
Aug 27, 2015 11:54 AM
bluegrassz
Jan 26, 2004 11:00 AM
MelloYello
Jul 15, 2003 10:29 AM
IROC57TPI
Mar 3, 2003 06:49 PM
Pablo
Oct 9, 2001 06:40 AM
