Will these valvesprings work with the LT4 hot cam??
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Just as the subject says.
Will they work ok with stock L98 heads. Maybe with screw-in studs. Or would they be ok with the stock studs.
Comp Conical Valvesprings
Thanks.
Oh yeah, I will be using 1.5 RR's. The hot cam I think has a max lift of .492 with 1.5's if im correct.
Thanks.
find out what spring specs the cam requires and buy a set from comp or lunati to match the specs. if you're going to or considering screw in studs it'd be foolish not to machine the spring seats bigger. i'd stay away from the conical springs, just seems like a way around doing the job the right way. same goes for using pull out studs, there's no real reason not to use screw in studs.
Transmission: 4L80E/4L80E
The lift would be .492 w/1.5:1 rockers. But, they always recommend 1.6:1 with it, making the lift .525 ( http://www.sdpc2000.com/cart.asp?act...d=989&pid=1087 ).
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Do you think the spring rate would be ok with the cam lift?
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Thanks, thats what I thought.
I figured that the LT4 Hotcam would work good with the L98 heads with using the .492 lift and a stock bottom end. Of course I am running a carb and not a TPI.
There are also non-shoulder screw-in studs available.
I don't think I'd do that kind of work with the heads on the car, though.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
Yeah, the non sholder studs were the ones I was going to use.
The key to taping the heads while on the motor is using grease on the drill and the tap. Also placing towels or rags in the right places help. I think someone posted a article on it here at thirdgen.
Car: Camaro
Engine: Carbed L98
Transmission: TH350
I thought it over, and think I will just run the stock bottom end and heads this season.
Car craft has a buildup of the GM 350 HO motor. It has vortec heads and is running the Lt4 Hot cam with 1.6 rr's. They are getting 401 HP and 428 TQ.
Im thinking of doing this to the L98 long block. Should be somewhat close to those numbers. The L98 will have more compression than the HO motor.
What do you guys think?
Car: 1991 Camaro Z28 5.7 G92
Engine: L98 Tuned Port Injection
Transmission: TH700R4
Axle/Gears: 3.23 Posi G80
Yess do it, I am glad to see that someone else is going to use 1.5 rockers, besides the vortec heads flow best around .5 lift anyway. I have 1.5 aluminum RR with my vortec heads and hot cam and it runs like a beast!! I am using comp 981-16 sprins and have had no problems, it still revs up to 6000+ easy.
1988iroc350tpi
Aug 14, 2015 07:52 PM
