new member, got some questions...
Old Sep 3, 2007 | 04:32 PM
jpvulpes's Avatar
just got the car a week or so ago, body needs a lot of work but it seems solid underneath and and engine and trans are good.gave it a tuneup, advanced the timing a bit and played with the carb a little. engine runs great and has tons of torque.. pings a tiny bit because of the timing but i have 87 in there. 93 should fix it... its not fast yet but hey its a stocker lg4, right?any how, my first question is... at WOT, the trans like to upshift at around 3500 from first to second. can't get it to stop doing this. sometimes it goes to redline and sometimes it upshifts early and its always at this RPM or around it... play with the TV cable or modulator? or is something just screwed up in the trans?also, any place i can get decent body panels? i need 2 fenders and a driver-side door skin. possibly a driver-side quarter panel skin, too.
Old Sep 3, 2007 | 08:39 PM
phess11's Avatar
Car: 83 Z28
Engine: 305 (LG4)
Transmission: THM700R4
Axle/Gears: 10 bolt, 3.23 non-LS
Re: new member, got some questions...
you can get fenders from classicindustries.com
Old Sep 3, 2007 | 10:33 PM
jpvulpes's Avatar
sweet thanks for the reply...
now if someone can help with the upshift problem i'll be good.
Old Sep 8, 2007 | 10:52 PM
jpvulpes's Avatar
tried adjusting the TV cable, same problem... tell me i'm not stuck manually shifting from 1-2-3...
Old Sep 8, 2007 | 10:59 PM
Toehead's Avatar
Car: 1985 Berlinetta
Engine: Megasquirted TPI
Transmission: Transgo 700R4
You may have better luck asking in the transmission board. I assume you have a 700R4?
Pac J
May 17, 2020 10:44 AM
92rsvortec350
19
Oct 9, 2015 09:39 AM
LT1Formula
Oct 8, 2015 08:34 PM
PAFORM350
Wheels and Tires
Oct 2, 2015 07:21 PM
