Codes
Car: 1989 camaro
Engine: v8 fuel injection
Transmission: automatic
Codes
I have a 1989 camaro rs 305 tbi and I checked the trouble codes and i get a code 22 and code 42 how do i fix the problems?
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: Codes
I think 22 is the TPS sensor out of adjustment, and code 42 is the timing. That one will set if you disconnect the black/tan connector to set the timing. You can ignore it if you have set the timing recently.
Re: Codes
There is a tech article on this site on adjusting the TPS and IAC sensors.
