alternator question and window wash pump question
Old Sep 4, 2007 | 08:00 PM
chevycamaro91's Avatar
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
Axle/Gears: posi 373
1. i did a tbi-carb swap. my new alt. has a spot to plug a 2 wire connector into and a bolt on the back for a wire. the wires i have from my old alt are a little different. i have a plug with 2 wires(red/black) but it doenst fit into the new alt, and i have another red wire with an end to go onto the bolt on the back of the alt. the red wire coming fromt he connector goes tot he starter, the black goes into the d/s harness that leads to the interior. the red wire with the the connector for the bolt is about 3 feet long and the end is just cut off. not sure where this goes?? any input would be cool
2. connector for the window wash pump- red connector with pink wire with black stripe, and green wire with yellow stripe. theres a pink wire with black dtripe coming from d/s harness intot he interior but i have no idea where the green wire with yellow stripe goes? haha
Old Sep 4, 2007 | 08:34 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
Re: alternator question and window wash pump question
well the larger wire that comes right off the battery, positive(red) goes to the stud on the back of the alternator. You can get the correct white plug for the 2 wire post at the local auto part store on the turn rack thingies.
there is a plug on the bottom of the round cylinder part of the washer pump/wiper assembly as well as one up higher. near the black cover
Old Sep 8, 2007 | 09:50 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
alright im a little confused. i attached a few pics of the wires that are still in the car that are from the 305 tbi. alright from the connector, red wire goes to starter and black goes into interior somewhere. and the 3rd wire, the wire with the circular end is about 2 1/2 ft long and has a cut off end on it. any idea where it goes??
Attached Thumbnails alternator question and window wash pump question-sertw34.jpg   alternator question and window wash pump question-picture-005.jpg
Old Sep 8, 2007 | 10:15 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
what do you mean the wire with the loop has a cut off end? does it go to the battery, and have an extra cut off wire? or is it just a cut piece of wire floating around with a loop on one side?
The other is the alternator plug, is goes in the alternator, the hole for it is in the side of the alternator, close to the stud on the back. It may be a different configuration than what the alternator accepts, so if this is the case you will need to go out and buy the right connector and replace it.
ahhh i finally figured out the first pic, yes that is the port where the alt plug goes, now it is different than the one you have the pic 2. I bought a new pigtail of the same configuration from the local National Auto Supply. It was on a blistercard and was called a gm alternator connector or something like that.
Old Sep 9, 2007 | 08:29 AM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
yea the alternator plug is different so im gonna have to get a new one. but yea as for the 3rd wire the one end has the loop on it and the other end isnt connected to anything, so im guessign the end with the loop goes to the stud on the back of the alt (?) but where does the other end go? battery?
Old Sep 9, 2007 | 03:00 PM
//<86TA>\\'s Avatar
Car: 86 Trans Am
do you still have the origional battery cables? If you do, take a look at the positive (red) cable end, where the cable comes out, and you will probably see the other cut off end still there.
Old Sep 9, 2007 | 03:11 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
good point, but no the pos cable has no end cut off of it. is there any chance it may go to the junction block?
Old Sep 9, 2007 | 10:44 PM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
thats a good place to check. my 84 is routed there.
Old Sep 9, 2007 | 11:21 PM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
well i think im goign to try running it to the junction block and see what happens
Old Sep 10, 2007 | 01:19 AM
as for your washer wires, both go to the switch.
Old Sep 10, 2007 | 05:22 AM
Car: 91 camaro
Engine: 383 stroker
Transmission: t5 :(
yea i ended up figuring out my washer wires. there are 2 wires in the headlight harness (blue and red) that hook up to the connetor for the washer pump. thanks though
RazorN8
Jan 7, 2022 11:44 AM
Vintageracer
Jan 10, 2020 05:33 PM
pfsteichen
Feb 9, 2016 06:59 PM
redmaroz
Aug 16, 2015 11:40 PM
IROCZDAVE (88-L98)
Aug 6, 2015 03:51 PM
