dissy off a tooth,burn rich?
Old Sep 5, 2007 | 09:41 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
if my dissy is off a tooth what would it do either way ,tooth off behind ,tooth off ahead? because mine isn't running right (can't seem to time it) everything is new ,but ,it will run i think rich cuz it puts off strong fumes from exhaust.
Old Sep 5, 2007 | 01:55 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: dissy off a tooth,burn rich?
Off a tooth would mean you have to turn the dist cap a lot to get the timing back to spec.
Is your ignition timing set right?
Strong fumes also can mean a misfire, check for that.
Old Sep 7, 2007 | 11:42 AM
bbsr72's Avatar
Car: 91 formula
Engine: 350 tpi
Transmission: auto
Axle/Gears: poss
it was off a tooth or two .took it back out advanced it and all systems go. i had it running too tardy.
Thornburg
Aftermarket Product Review
Oct 6, 2015 12:04 PM
gord327
Oct 3, 2015 01:25 PM
Luigytico09
Oct 1, 2015 08:46 AM
1Aauto
Sponsored Vendors
Sep 23, 2015 12:56 PM
89fast5oh
Sep 8, 2015 09:55 AM
