Fuel Problems (Walbro 340GSS)
Old Sep 7, 2007 | 07:59 PM
metalic5's Avatar
Car: 87 GTA
Engine: 5.3 LSx
Axle/Gears: 3.70 Borg Warner 9 bolt
can too much voltage to the fuel pump cause a loss in fuel pressure as you rev the motor?
i'm getting somethin glike 15.5 volts to my walbro, as i drive and get on it i keep on getting fuel starvation, loss in fuel pressure and the car just boggs out. i got a full tank of gas, and *** the pressure goes down and the car starts to bogg the pump starts to whine at a real sharp pitch.
i was told that i could be too much tank pressure. i checked and theres not too much pressure so thats out of the question as a factor. i was also told, that the pump may be too low in the tank, i dont think so cuz it just started acting up from one day to the next.i thought it was the pump so i put a new one and a new filter, and still nothing.
my set up is a walbro 340gss with an aeromotive fuel pressure regulator.
Old Sep 7, 2007 | 08:28 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
Re: Fuel Problems (Walbro 340GSS)
that is a bypass reg you are using correct? not a dead head? or aeromotive calls it a static reg
Old Sep 8, 2007 | 12:33 AM
metalic5's Avatar
Car: 87 GTA
Engine: 5.3 LSx
yea it's a bypass regulator
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
AkDrifted
Aug 17, 2015 07:45 PM
92camaroJoe
Aug 13, 2015 06:07 AM
