The real reason the DZ302 SBC revved so high...
Car: 1983 G20 Chevy
Transmission: 4L60
Re: The real reason the DZ302 SBC revved so high...
jon, I agree with Fast emphatically. Now a 305 has some limitations just because of the very small bore which that limits head selection. And, building an engine to rev so high THAT WILL SURVIVE is another matter again (which you will see after you read this).
Your example would be simpler if it was an L98 (and pretend that you were dumping EFI and going with a carb)...yes the 350 would rev damn near the same as the DZ302 (though max TQ would be higher and peak HP would occur approx 500 rpm sooner). But, the L98s interals would probably not survive very long if you kept taking it to those rpms on a regular basis.
This is when you would want forged internals (crank, rods & pistons) that would be able to handle those high rpms on a regular basis. As well, you would probably be best to have a 4 bolt block instead of a 2 bolt block.
But, as Fast355 just said, with today's modern technology, I would go with a modern solid roller cam; something like a buddy of mine is using ... 248/256* @ .050 with .600" lift as well as modern heads say AFR 195s or maybe even AFR 210s. Lastly, a better intake say a Victor. And to compare all things equal use the 11:1 compression ratio, but on a real engine I would recommend dropping that at least a 1/2 point even with aluminum heads so it can survive on today's pump gas.
That engine will also rev like crazy and probably make around 485 TQ @ 5,000 and 550 HP @ 6,500 ...more than the DZ302 was ever claimed to make.
And if you stroked it to 383, that same combo would make roughly the same HP but 250-500 rpm sooner (which is a good thing in my books). However, TQ would increase over the entire TQ curve, especially the lower RPM range by around 30-35 lb/ft with peak TQ now around 515 lb/ft just before 5,000 rpm. You can see, even when just comparing a 350 to a 383, the HP still remains nearly the same but you get that extra TQ through out the lower rpms and end up with a better engine IMO for both the street & strip.
But you would definitely want good forged internals with a 4 bolt block to ensure it can handle the extreme forces when reving out and "keep it together". And this is where I would have problem trying to do this to a 305 as 305s are all two bolt. If you start getting into the machining costs to convert it to a splayed 4 bolt, the cost alone would make it simple economics to start with a good 350 4-bolt core instead (as well as the fact you cannot bolt on a set of AFR 210s).
GM DID make some 4-bolt main 305 blocks. I personally have TWO of them. I would however, in a higher budget build, start with a 2-bolt main block and splay the main caps. You can get away with 6,000 rpm useage with 2bolt mains, good ARP main studs, and a good align bore.
Car: Death Mobile
Engine: 666 c.i.
You can build a 305 to survive, but it is going to cost you some. I have had good success with the late model GM Powdered Metal rods. I have turned several different engines with them to 6,500+ RPM and put MANY miles on the three. My G20 Vans 350 has them and already has 45K on it. It shifts 1-2 WOT @ 6,500 rpm. It has a factory forged crank, PM rods, and Hypereutetic pistons in it. It is also 4 bolt main.
But I was more thinking of the 3rd Genner building his own 305 (which are all two bolt), and with the proliferation of cheap 350 4-bolt blocks (I wouldn't use an stock L98 block either), it makes more economic sense to go with a 350 4-bolt block, especially when it can handle much bigger heads.
As for splaying, I personally wouldn't waste my time with these blocks (LB9 or L98) as well. They are not the best castings. And at these power levels, I want a better casting (there the DZ302 wins).
I am NOT saying "don't build a 305" and refuse to get into that debate (it's been beaten to death and just results in a locking the post). I am saying at THESE power levels which require heads similar to AFR 210 range (and AFR 210s won't work on a 305 without serious machining...and again gets back to simple economics).
And, as I explained in my previous point, I would probably go with a stroker 383 over a 350, as it costs basically the same since you will be changing all the interals anyway. You lose little or nothing in HP but gain in 30-35 TQ all over the lower & mid-range - and that will result in a better motor for both the street & strip (provided you build it right).
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Car: 1984 Z28
Engine: 383 Stroker
Transmission: t5
ok first off i have to say i'm a HUGE fan of the dz 302. Now i'm only 24 but my step dad has an all original 68 Z28. dz 302, muncie, 4.10 12 bolt. the works. His car has no power steering, no ac, no options what so ever. Not even a center consol. Now i have dyno sheets of this and can prove it. Friend of mine has a dyno. We dyno'd this car just to see what it would have. No lie this car made 394 HP at the rear wheels. And thats without thrashing on it. (my dad would kill me if i did) So with respecting the car (and my dad lol) i think that is very impressive for a 53k mile car and not making it scream to its potential. If i'm correct we let off around 6500 rpms. torque was lower as you all would know. These aren't torque monsters. I have built my own clone 302 (283, 327 cranks yada yada yada). Pink rods, have the double hump heads (2.02 valves) you all know what i'm saying. But i also did a little decking to the block, roller cam, rockers, lifters and such. Fully balanced. I had it in a 67 shortbed c10 and my shifter was shot. Missed third gear at the track, revved over 9k by accident. still ran a 12.2 in the quarter. Havent ran it on a dyno yet. Going to put it in my 77 z28 4 spd. If i dont find me a nice 3rd gen first.
Car: 1991 Formula Firebird
Engine: L98 with headers/exhaust
Axle/Gears: 3.23 10-bolt
Great thread! Enjoy the tech on both the new and old engines!
Guest
Posts: n/a
Most of the T5's relative quickness came from how bad the AOD really was, in stock form. The T5 was about a full second quicker just in the first 60 feet, I kid you not!
The AOD torque converter was half to blame, but the AOD's lame 2.40:1 first gear was nothing close to our 3.06:1. And most of the 5.0 / AOD 'stangs had 2.73:1 axles, not the optional 3.27:1 like I drove.
On the other hand, most of the T5 five-ohs had the optional 3.08:1 axle, not the standard 2.73:1 like I drove.
Gearing makes a definite difference. They used a 3.35:1 first, while ours had 2.95:1 first gears.
Engine: 383 Carb
Transmission: 4L60
Car: 1983 trans am
Transmission: 700-r4 B&M console megashifter
Does anybody know where I can get an engine diagram for an 84 firebird
Car: 1983 trans am
I don't know much about the car being as I just bought it a gte days ago here's the gin if that helps at all 1G2AW87H1DL220088
But, in reality, based on what you are describing, you really want the opposite. Assuming a cam with the same duration; the 302 with it's higher bore/stroke ratio, it is better off with a narrower LSA (110 or less) as it is naturally short on torque but high on HP. A narrow LSA will promote the much needed mid-range torque (while sacrificing a little top-end).
Conversely, a 305 with it's lower bore/stroke ratio that is more torque oriented, it benefits from a wider LSA (assuming all the remaining cam specs are the same) as it does not need to promote it's mid-range torque but could use a little help on the top-end HP.
Of course, we haven't even got into the cam lobe profile and retarding/advancing the cam. Which can greatly affect the torque/power characteristics of the cam.
But you are right, there is an interplay in all of this that most people don't bother looking at to see if they have a "good match". The "30-30" cam in the DZ302 was perfect for what it was really designed for: racing.
Frankly, even on a bigger engine like a 383, I feel the "30-30" cam would be completely wrong for a car whose primary use is for the street - even though it would be better on the street than the original DZ302 was. (But it sure would rev - and that is more what I am trying to convey to some of the younger members who believe that the secret to the DZ302 was it's bore/stroke ratio - when it was the cam).
Many times, the younger members of TGO listen to their dads (and grandpas) talk about the famous DZ302 (the original Z/28) engine and how it would rev beyond 7,000 rpm. Most attribute it to the short stroke. But, in reality, it was the camshaft that was the real reason.
I say this because I have helped build and tune a number of engines for various friends over the years (and yes, I actually could drive when the DZ302 was out and actually test drove one). I can tell you that the stroke is not the "magic secret" but the camshaft.
The camshaft was a solid flat-tappet cam with 254/254 duration @ .050 with .485/.458 lift. For those guys who know cams, they know that duration is huge, even on a 383. That is also the reason that car had absolutely no bottom end torque (and why I did not buy the car either).
That cam was designed exactly what GM primarily intended the Z/28 - RACING! GM only sold the Z/28 because it was a requirement to meet the Trans/Am rules.
For those people that doubt me, I suggest that instead of trying to 'destroke' their 350. Instead, install that cam (Crane makes a blueprinted copy which Summit sells P/N CRN-967251) in your 350 instead. It would be best if you could also get a copy of the heads, but with so many great aftermarket heads today, you can easily find a better head that will flow more.
Trust me, that same cam with the better heads we have today will rev just the same as the original Z/28 and though you may not have the same compression ratio (again a good thing as we don't have gas with enough octane to support the original Z/28's 11:1 compression ratio), you will have not only an engine that will make darn near the same power and rev the same BUT you will have something the original DZ302 never had - TORQUE!
But when this cam is installed in a 350 (with decent flowing heads) you can have everything that was great about the DZ302 without it's one weakness (lack of torque). You can now have your cake and eat it.
The stroke was never the secret to the DZ302's ability to rev, it was the cam. But most of us old-timers knew this.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
If you are willing to run the high ratio rear gears 4.56:1 ish you can build a 10:1 - 10.5:1 cr 305 with a .500"-.530" 245-254° @.050 108/110LSA solid cam and 1.94 x 1.50 valve ported heads, headers 750 carb and high rise intake that will rev up just like a 68 302 Z/28 make more power and run like hell.
It will do everything a old DZ302 ever did.
You want to strip down any unnesessary weight from your 3rd gen just as was done on street strip 67-69 Camaros. The T5 manual 5speed will work great.
A Auto trans will want a very high stall 8" -9" race converter 5000 stall target. But it will drive well also.
A th350 will work better overall than a 700R4
Easy 12's just like the street strip 302 Z/28's ran.
You can have a modern 305cid version of this high reving lil solid lifter 302sbc that does exactly what the old guys brag about but run on 92 premium unleaded.
The key on the smaller bore 305 cid version is when choosing and prepping your cylinder heads go with a 1.94" valve VS the 2.02" valve. Once the head is ported and prepped correctly there is no disadvantage at this build level.
I don't see anything.
Since this old post was brought back to life, I have a few thoughts to add...……..
And yes, I do have a 302 Chevy running on the engine test stand.
I am not trying to start any arguments - just participate in a discussion.
And I was 2 years old when these 69 302DZ Camaros were being sold at the dealerships.
First question though: if it's the camshaft (and not the short stroke) that is responsible for the high revving capability of the 302, then how do you explain the 283 Chevy being able to rev to 8000 rpm easily? None of those had huge camshafts. The 302 is an overbored 283 and shares the same 3.000" stroke. Racers of the time would bore the early thick-walled blocks .125" over to make a 301.
Blackdog36
20
Jan 11, 2015 02:20 PM
