3.73 gears overkill??
Car: 89 formula 350
Engine: 5.7L (L98)
Transmission: 700R4-(shift kit,corvette servo)
Axle/Gears: borge warner-3.27
Does anybody run 3.73's in there 9 bolt rear end and if so how well does it perform? I was actually thinking of upgrading from my 3.27's since the rear is going to go through a rebuild anyway. I am a little afraid that it might be overkill but am not worried about top speed as much. Since these motors make gobbs of torque I wanted to get the best launch possible during racing. Anyone have feedback on this? Looking to do this very soon.
Car: 1988 Firebird S/E
Engine: 406Ci Vortec SBC
Re: 3.73 gears overkill??
When driving on the highway @ 60 MPH in OD, your engine rpm will increase by 250 rpm if you swap in 3.73's for your 3.27 gears. You worry too much.
Car: 86 Trans Am
Engine: 408 stroker sbc
Transmission: TKO600
i thought 3.45 was the lowest gear made for the 9 bolt? hmmm
Car: 89 formula 350
Engine: 5.7L (L98)
I thought that the 9 bolt had an aftermarket 3.73 option. Maybe I'm wrong. Somebody enlighten me on this. I want to get the best bang for my dollar without over reving out of my torque range.
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
A nine-bolt would be 3.70's, not 3.73's, although the difference would be miniscule.
JamesC
JamesC
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
3.73's are over kill. Well with a 5 speed and 350 not sure how they would be with a automatic. stay with 3.42's at the most, plus 3.73's eat gas bad.
The L69, a 305 HO, was equipped with a 5-speed and 3.73's. Kicked 'Vette" butt back in the day. So overkill?
JamesC
JamesC
Car: 1989 GTA
Engine: 369 TPI
Axle/Gears: 3.70 Nine Bolt
I have them on my car. Actually 3.70 Borg Warner gears. I have the 700R4 and would not want to go any lower for a street vehicle. I can still get 20+ mpg on the highway with a motor that is putting out well past 400hp at the crank. If you had a six speed there is no issue and maybe you could go a little lower.
Car: 1992 rs 355 TBI **swapped**
Engine: 80 Ford Fiesta GHIA dual carb
Transmission: 72 Cutlass S 350/350 3.42
Axle/Gears: s10 tq converter/stock rear gear
yep, 373's are pretty harsh with the low first gear of the 700r4.... I hear a lot of people say they love their 355's and 342's on the street especially with an auto, dunno bout a 5 speed, how does their first gear ratio compare?
James in what day did they kick the vettes butt LOL .... maybe in 84 but thats it ... if they did even then. the 5.0 ho cars were mid 15 second cars I never saw the appeal of the engine the was really nothing incredible or exhilerating about it, just a hopped up taxi engine LOL
Car: 1988 Camaro Sport Coupe
Engine: L03 305 TBI
Transmission: Five Speed
Axle/Gears: 3.08
I have them on my car. Actually 3.70 Borg Warner gears. I have the 700R4 and would not want to go any lower for a street vehicle. I can still get 20+ mph on the highway with a motor that is putting out well past 400hp at the crank. If you had a six speed there is no issue and maybe you could go a little lower.
Just kidding I know you meant MPG.
I had a car with a TH350 and 4.10s, I would not want to drive that as a daily driver.
Car: 1987 Monte Carlo SS
Engine: 400 SBC
Transmission: 200-4R
Axle/Gears: 4.10
3.73s are fun. They're not overkill, but they are less economical than 3.42s, which still give good performance. I have 3.73s (stock) in my SS, and 3.42s in the 'bird. They both have their strong points. Obviously the lower gear helps in the bigger car.
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
Car: 89 Iroc-Z
Engine: 5.7
Transmission: 4 spd auto
I went from 2:70 to 3:73s in my 9 bolt, got them from Differential Techniques. They are as quite as stock gears. I also have a 2600 hundred stall convertor. Definitely not overkill, fuel mileage drops noticably but 23 to 2400 rpms on the freeway is not bad.
Good gear with my 350. I have a very mild cam (214/220. 452/465) an Eldebrock base and AS&M runners, no headers good catback. I like them.
GWW
GWW
Car: 1988 Camaro
Engine: 383 Stroker
Transmission: Probuilt 700 R4
Strange made a 3.73 for the 9 bolt, costed me 350 for the gears. Its quite a holeshot with the 700 r4 with a 3.06 first gear. And the nice thing on the highway cruising at 60 i am only pulling 1700 rpm
Car: 1986 Camaro SC
Engine: Bolt-on/cam 305
Transmission: 700R4 w/ 2500stall
Axle/Gears: 3.73 10bolt Posi
I run 3.73's behind my 700R4. I love it! As long as you've got a good set of tires, a relatively stock 350, driven right, should still hook with that gear. I've got a 2500rpm stall with those gears, behind a mild 305, and it holeshots very well. The fuel mileage will expectedly drop some, but you've got to make a few daily-driver vs. toy compromises, and a rear-gear change can make a car feel like a new beast.
Engine: 400 SBC
Axle/Gears: 4.10
You're tach is wrong, or you're running some seriously tall tires. My SS has 3.73s and a 200-4R, with a more conservative overdrive than a 700-R4 I run about 2000 rpms at 60mph. My 'bird runs between 1800-1900 at 60mph with 3.42 gears and a 700-R4.
1700rpm sounds about right at 60mph ... my 84 when new turned like 2,000rpm at 65 in OD with 373's ... my 5 speed 373 turns about 2000-2100 at 65. But his tach might be a little off or he is running taller tires. Mine has 235/60/15's and din't the OD's change throughout the years? I've heard of 2 OD's used in the 5 speeds for V-8's ones like a .74 and the other is like a .63 or something like that.
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
GWW
GWW
Where are they located?
Web site?
All of the 3.70 gears I have got were all noisy as hell.
So I am looking for some that aren't.
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
Ditto the above comments........For your statement to be true, you'd have to be running 31" tall tires ! Are you?
Car: 1986 Camaro SC
Car: 1989 T/A
Engine: PROCHARGED LB9
Transmission: FB BUILT 700r4 2200 stall
Axle/Gears: 10 BOLT EATON 3:73 POSI
do a search in the tpi forum,, lots more info. and people who have made the switch. all i can say is
Zeek1041
Theoretical and Street Racing
Sep 30, 2015 11:00 AM
rudolphschenker
Sep 4, 2015 02:41 AM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
I made the correction.
