Fuel lines question...
Old Sep 12, 2007 | 10:23 AM
Jb87IROC's Avatar
What exactly do you call the male ends on 5/16 and 3/8 hard lines? I'm guessing -6 an and -8, but I want to be sure before I spend money to run lines to my new Carb.
Old Sep 12, 2007 | 11:38 AM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: Fuel lines question...
It depends on how the end of the hard line is finished. 5/16" and 3/8" correspond to -5 and -6, if you're using AN fittings.
Old Sep 12, 2007 | 11:48 AM
duckmanquacker's Avatar
Car: 84 Z28 / 88 Trans Am / 87 base
Engine: L69 H.O. / 468 BBC / 2.8 v6
Transmission: 89 700R4 / TH375B / 700R4
Axle/Gears: 3.73 open / 3.23 posi / 3.42 open
I believe they are the double flare not the an design.
Old Sep 12, 2007 | 12:04 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
It depends on the line. If you're talking about stock carbed fuel lines, they're just barbed on the ends. If they're stock FI lines, they're some bizarre-sized Saginaw fitting.
Old Sep 12, 2007 | 12:16 PM
Jb87IROC's Avatar
Ehhh that sounds like fun. Yes I have the stock FI lines, I switched to carb. I took the rails off all the way to the frame of the driver's side. Right now I just have rubber hose over the fuel lines and double clamped down. I have a feed, gauge, return, and two outs screwed into my mallory 4309. Any suggestions?
Old Sep 12, 2007 | 12:27 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
I'd trim the ends of the hard lines and flare them for AN tube nuts and sleeves, then run braided hose from there.
Frozer!!!
Jan 19, 2024 04:55 PM
theshackle
Mar 5, 2017 06:37 PM
Andrew6.688
Dec 13, 2015 10:59 AM
AkDrifted
Aug 17, 2015 07:45 PM
