Help diagnose 355 running Sh*TTY
Old Sep 17, 2007 | 12:26 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
Axle/Gears: one wheel peel
i just have got the 355 in my camaro.....i have her wired up as best i can tell with the spark plug wires on all the right terminals.....it absolutely wont crank unless u retard the electronic timimg.....it runs like **** until u advance timing a lil bit.....even though it evens out on advancment....it still pops and carries on..... ANY BODY KNOW WHAT THIS COULD BE?
Old Sep 17, 2007 | 12:32 AM
TPI's Avatar
Car: '89 Trans AM/'88 GTA
Engine: (2) Tuned Port L98's
Re: Help diagnose 355 running Sh*TTY
You TPI or carb?
Sounds like your off a tooth, or 180* off.
Get her back to TDC compression stoke and start over,
walk the cam till she is pointing directly at the #1 cylinder.
If TPI, Does it change when you connect/disconnect
your EST bypass? I think you just need to try again?
Sometimes I still screw up =P
Old Sep 17, 2007 | 12:37 AM
jay_d's Avatar
Car: 84 z28
Engine: 355
Transmission: TH350
it's carbed....it aint 180 out....i done fixed that problem eariler today....i may try just doing it over....i remember when i put the dist. in the pointer was like half way in between terminals.....but like i say......the more i advance.....the better it runs
eightsixseven
Dec 16, 2024 01:50 PM
theshackle
Mar 5, 2017 06:37 PM
Reddeath210
Oct 6, 2015 08:20 AM
Bryan F
Aug 18, 2015 02:28 PM
355tpipickup
Aug 13, 2015 07:35 AM
