poly or stock motor mounts
Old Sep 18, 2007 | 12:07 PM
luke84's Avatar
Car: 1984 z28
Engine: 355
I was wondering... do the poly motor mounts raise the engine up higher than stock rubber mounts? Seems like I have heard this on here somewhere before but i searched and found no answers. Need to replace my mounts, but if the polys raise up another inch over stock i'll use rubber.
Old Sep 18, 2007 | 12:28 PM
Sonix's Avatar
Car: 1982 Trans-Am
Engine: 355 w/ ported 416s
Re: poly or stock motor mounts
No, they certainly won't raise it an inch.
If your stock rubber ones are worn out, and your engine is sagging 3/8", then the new poly ones will "raise" the engine 3/8". So will new rubber ones though.
So no, they don't change the height of the engine from *where it's supposed to be*
Old Feb 8, 2008 | 10:33 PM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Also , IMO ,I would never go through the nightmare of replacing the mounts/frame pads with stock units. Poly units only for me. I did it for the first and last time hopefully with Energy Suspension (red) pads from Auto Zone for about $60.00 a set.( there supposed to last) Took my time and from start to finish about 5 hours buy myself. Buy the way, I needed two wobblers in-line through the passenger side spring to get at the hardest nut. Don't want to do that again any time soon.
Old Feb 9, 2008 | 04:36 AM
82Five-O's Avatar
Car: 82 Sport coupe
Engine: 355 semi roller
Transmission: TH-350 B&M ratchet shifter
Axle/Gears: 3.73 Eaton Posi
Jeremys87
Jul 14, 2022 09:08 PM
customblackbird
Aug 15, 2021 10:16 PM
TreDeClaw
Theoretical and Street Racing
Jun 22, 2021 08:21 PM
Elliswon
Aug 10, 2015 12:33 PM
NBrehm
Aug 5, 2015 07:57 PM
