24lb injectors
Old Sep 21, 2007 | 08:04 AM
sauceman's Avatar
24lb injectors
is there going to be any problem running 24lb injectors on a stock 5.7?
its a 91 z28 with just exhaust
Old Sep 21, 2007 | 11:38 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
Re: 24lb injectors
Yes. The computer PROM is setup for 22lbs injectors and to run rich at wide open throttle, so the engine will run even richer with the 24lbs. Its better to get a custom chip programmed for the 24lbs injectors before you use them.
92-Formula
Dec 12, 2015 10:34 PM
rubyred88
Sep 17, 2015 02:19 PM
thejimsterz28
Sep 15, 2015 04:37 PM
BAMiller
Sep 14, 2015 06:38 PM
webeeZ28
Sep 14, 2015 12:00 PM
