causes of no compression
Old Sep 24, 2007 | 06:04 PM
TAtothefloor's Avatar
i just rebuilt the topend of a 350 the bottom end is in good shape with low miles and for some reason i cant get any compression readings (0) out of it when i trurn the motor over by hand it is hard to turn so i beleive the rings arent bad and i have all new heads cam lifters any ideas of what the problem could be or things to check for? i used the gauge on my truck and it works. i had a buddy do the timing chain and i think he messed up could it have sent a valve through the piston? i never heard any bad sounds out of it. i redid the timing chain and still nothing. and a weird thing is that i had the motor runing before and now it wont run.
thanks for any help
Old Sep 24, 2007 | 06:14 PM
Vader's Avatar
Re: causes of no compression
Back off the rocker adjustments and try it again.
Were the valves reworked?
Old Sep 24, 2007 | 06:21 PM
the heads were rebuilt totally by a machine shop
FormulasOnly
Jul 23, 2018 08:47 AM
69GTOby
Apr 18, 2016 02:34 PM
Nervous2
Oct 8, 2015 10:53 PM
Jonas Earl
Sep 27, 2015 07:39 AM
WhteRbt
Sep 21, 2015 09:48 AM
