crackt block fixable??
Old Sep 28, 2007 | 09:18 PM
karrfirebird87's Avatar
Engine: 350 4 boltmain goodwrench crate
Transmission: 350 turbo 3 speed
Axle/Gears: i belive its a 323 gear ratio posi
hi ,, i recently discovered my 350 4 bolt main block has cracks on the passenger side of the block is that fixable??
Old Sep 28, 2007 | 09:19 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: crackt block fixable??
Possibly. Whether or not it's worth it is another question.
Old Sep 28, 2007 | 09:22 PM
ok , well its completly clean besides the crack it has about 4 on that side that strech about 1 inch long looks like a result of over heating ,, what do you think?
Old Sep 28, 2007 | 09:24 PM
Apeiron's Avatar
Engine: 383 Carb
Transmission: 4L60
Ask a local machine shop what it would cost to fix it. Considering how cheap a bare block is, unless you have some sort of emotional investment in the block, it probably won't be worth it.
Old Sep 28, 2007 | 09:27 PM
ok i get it ,garbage,, thanks for the info ,, an no its not a investment at all it was free
Old Sep 29, 2007 | 01:15 PM
sqzbox's Avatar
Car: 88 formula WS6
Engine: 305 Lo3
Transmission: 700-R4
You have 3 options:
1. grind the crack lightly to bare metal and coat it with JB weld. (I have persoally done this with sucess after 3 yrs. It's still holding I figure that it will continue to hold as long as I have my spare engine in the garage)
2. You can get it repaired at a machine shop. ( they will drill overlaping holes and install overlaping studs the length of the crack)
3. If it's not leaking, you can do nothing. (most water jacket cracks are caused by freezing from insuficiant coolant in winter and cracks start from the outside in)
I have a 3 inch crack on both sides of the 350-4bolt in my truck. 1 was leaking and 1 wasn't. I JB'd the 1 that was and haven't had any problems yet.
So far, I have over heated it 3 times once from a waterpump failure, and twice from pluging up the radiator with mud from the mud bog's. I pull 5500 rpm through the mud,
Option 1 and 3 are ok for stock but if you are going to do some serious power upgrades I would consider option 3 or junk the block or, keep a spare engine in the garage like I do. In that case, the cracked engine will probably run a long time while you build another engine on the stand at your liesure!
sheachopper
Jul 31, 2019 11:27 AM
Cam-aro
Camaros Wanted
Nov 12, 2015 03:35 PM
skinny z
Oct 5, 2015 06:23 PM
92projectcamaro
Sep 29, 2015 07:07 PM
dusterbd
Sep 29, 2015 08:40 AM
