Fuel pickup and lines
Old Sep 30, 2007 | 09:12 AM
Batass's Avatar
Car: 91 rs
Engine: Blow through 383, 10 psi, xr288hr
Transmission: Manual th350 ATI 3000
Axle/Gears: 3.50 9"
Im removing my pump and putting a peice of hose in its place and running new 8an braided to the motor. Do I need to keep all the fuel lines? Obviously I need pressure and return and a vent, but which one? The short section that ends behind the seat or the one that "used to run" to the evap can?
The other question is, I'm shooting for between 650-750hp. Will the stock lines in the tank flow enough fuel? Im using an A1000 pump.
Old Oct 1, 2007 | 05:05 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Re: Fuel pickup and lines
ttt
Old Oct 1, 2007 | 05:20 PM
SpitotRs305's Avatar
Car: 91 RS
Engine: 350 vortec
Axle/Gears: not the best not the worst
i dont think the stock lines can flow enought fuel for that power level... but if you are serious about 650-700 then you would be replacing the stock lines anyways
Old Oct 2, 2007 | 04:48 PM
Batass's Avatar
Car: 91 rs
Axle/Gears: 3.50 9"
Your right better safe than sorry, ill just run the line right down through the tank.
theshackle
Mar 5, 2017 06:37 PM
Winchester1094
Aug 18, 2015 10:23 AM
AkDrifted
Aug 17, 2015 07:45 PM
Kaweh
Aug 9, 2015 02:54 PM
