roll pin removal? HOW???
Old Oct 1, 2007 | 12:42 PM
jos385536's Avatar
Car: 1992 Camaro RS
Engine: 305 HO
On my camaro Ive found my pickup coil to be defective. In order to replace it I have to take the distributor apart and it has a roll pin in it holding it all together. I've tried beating it out, pressing it out, and wedging something between the pin and what it's holding together to make it smaller but it still won't come out after about 45 minutes of trying. I don't want to spring $100 to buy a new distributor all because of that f***ing pin.Any reccomendations on how to remove it?
Old Oct 1, 2007 | 12:46 PM
Apeiron's Avatar
Car: 1984 Z28 Hardtop
Engine: 383 Carb
Transmission: 4L60
Axle/Gears: 3.54 Dana 44
Re: roll pin removal? HOW???
Drive it out with a punch.
Old Oct 1, 2007 | 12:49 PM
BADMAN's Avatar
Car: 1985 Iroc-Z
Engine: 440LSX
Transmission: l460e
Axle/Gears: 3.55 Wavetrac
There are roll-pin punches made to knock out the pin. Go to Sears and look for a set. If you are talking about the one holding the dist. bottom drive gear, they can be a PITA due to the force on them. Try a roll-pin punch.
Old Oct 1, 2007 | 12:59 PM
89RsPower!'s Avatar
Car: 86 Corvette, 89 IROC, 1999 TA
Engine: 350, 350, LS1
Transmission: 700r4, 700r4, T-56
Axle/Gears: 3.07, 373, 4.10
if it comes down to it simply drill it out with the correct size drill bit and replace it with a new one..
Old Oct 1, 2007 | 01:00 PM
jos385536's Avatar
Car: 1992 Camaro RS
Engine: 305 HO
That's the exact one i'm talking about
Old Oct 1, 2007 | 01:17 PM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Try these
http://www.sears.com/shc/s/p_10153_1...yword=Roll+Pin
Drill a hole on a block of wood, lay the gear across the wood and knock the pin into the hole.
Use some B-12 (Carb cleaner) to soften up any oil deposits that would make the gear hard to get off the shaft and to get the shaft loosened up and out of the housing.
Frozer!!!
Jan 19, 2024 04:55 PM
Vintageracer
Jan 10, 2020 05:33 PM
Night rider327
Sep 2, 2015 04:17 AM
gixxer92
Sep 1, 2015 04:32 PM
3rdgenparts
Aug 8, 2015 07:09 PM
