why do i have 2 map sensors? and weres the line go?
Old Oct 7, 2007 | 03:02 PM
84noname's Avatar
ok i have 2 map sensors, one on each side of the back firewall the drivers side one goes to the nipple on the back of the carb, the one on the passenger side has no line going to it and i cant find the line. someone know where it goes? its a 84 s/e 305
Old Oct 7, 2007 | 05:31 PM
Fullsizewagon's Avatar
Engine: '85 Monte SS L69 305
Transmission: TH 200-4R
Re: why do i have 2 map sensors? and weres the line go?
Sounds like you have a Baro sensor on the passenger side. It measures atmospheric pressure, and so has no line on its port but maybe a piece of foam rubber (or some remains of it). Someone correct me if I'm wrong.
Old Oct 7, 2007 | 09:15 PM
Damon's Avatar
What fullsizewagon said- one is a VAC sensor and has a line back to the carb/intake. The other is a BARO (atmospheric pressure) sensor with looks identical, but there is no vacuum line attached.
Old Oct 7, 2007 | 10:22 PM
84noname's Avatar
sweet, he was exactly right, remanants of some foam stuff on it cool well i learn every time i post on here and work on my car. theres hope for my ford butt after all, i like gm's i just dont know too much about them. you guys are a enormous help as usual thanks
92camaroJoe
Jul 29, 2023 07:57 PM
9192camaro
16
Feb 3, 2019 12:21 AM
91REDZ28VERT
Aug 18, 2015 10:16 PM
92camaroJoe
Aug 13, 2015 06:07 AM
squiggy2
Aug 9, 2015 09:30 PM
