can I use 1.6 rocker arms?
Car: 87 Z28
Engine: 383
Transmission: th350
Axle/Gears: ford 8.8
If the heads specs says 520 is the max lift and my cam is 515 can I use 1.6 rockers?
If I did my actual lift will be about 550" can I do this without upgrading the springs?
the heads are dart pro 1
Re: can I use 1.6 rocker arms?
1.6's really don't give you enough of a gain in HP to risk it. If you're willing to spend the money on better springs, I'd say go for it, but even then, you're spending a lot of money for very little gain.
92rsvortec350
19
Oct 9, 2015 09:39 AM
