91 Z TBI, Where is the fan relay switch located?
Old Oct 7, 2007 | 08:52 PM
DREGSZ's Avatar
Old Oct 7, 2007 | 09:04 PM
KBcobra's Avatar
Car: 92 Chevrolet Camaro RS
Engine: 3.1L V6
Re: 91 Z TBI, Where is the fan relay switch located?
on the driver side there is 3 relays by on the top of the firewall. by the brake master cylinder
Old Oct 7, 2007 | 09:16 PM
Damon's Avatar
Only 2 relays on a TBI car. Fan relay is the one closest to the driver's side fender near the power brake booster.
Other one is for the fuel pump.
Old Oct 8, 2007 | 03:17 AM
DREGSZ's Avatar
Cool,
Thank you
I thought I was going under the dash. This should be much better.
E
Old Oct 8, 2007 | 03:47 PM
Kevin91Z's Avatar
Car: 1990 Pontiac Trans Am
Transmission: Tremec T56
Axle/Gears: 12-Bolt 3.73
91 Z TBI? That doesnt exist. 91 Z28's are TPI, and 91 RS's are V6 or TBI. Is that a typo?
The fan relays are as described above, while the fan switch is in the passenger side head between the #6 and #8 cylinders.
Old Oct 9, 2007 | 02:07 AM
DREGSZ's Avatar
Opps sorry, 91 Z TPI
you mean the brass sensor scews into the block btwen #6/#8?
What is the most likely part to fail if the fan isn't coming on?
the fan motor, relay? sensor? or something else?
THanks
Evan
Old Oct 9, 2007 | 10:26 AM
five7kid's Avatar
Transmission: 4L80E/4L80E
It's the one that you test and determine is not functioning properly.
Old Oct 9, 2007 | 10:36 AM
DREGSZ's Avatar
Having never gotten the hang for how an Ohm meter works, I just replace the part voted most likely to leave the island first and then the next and so on.
Old Oct 9, 2007 | 10:48 AM
battman's Avatar
Car: 87 GTA, 88 GTA, 92 TA, 72 RS SS
Engine: 350, 350, 305, 396
Transmission: T56, 700r4, 700r4, T56
Axle/Gears: 3.42, 3.23, 3.23, 3.73
Also check the connection to the fan switch, that connector is prone to getting brittle from the heat and breaking.
Old Oct 9, 2007 | 10:51 AM
ZZ28ZZ's Avatar
Car: 82 Z-28
Engine: 383 TPI
Learn to use the ohmmeter, it's really simple and will save you tons of money troubleshooting.
TPI cars have 2 radiator cooling fans.
The main radiator fan gets power from a relay as mentioned previously. That relay is controller by the ECM.
The secondary radiator fan gets power from a different relay. That relay is controlled by the thermal switch on the pass head as prev mentioned. The secondary fan relay can also be turned on by the air cond system if in use.
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
TA8487
Aug 16, 2015 12:21 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
