performance
Old Oct 8, 2007 | 10:01 PM
outlaw85t/a's Avatar
performance
besides cold air intakes what are some cheap ways to gain power out of an 89 formula 350 tpi.
Old Oct 8, 2007 | 10:21 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
The #1 best performance for $'s spent it to make sure everything is operating at its best - flow, spark, sensing, timing, etc.
Old Oct 8, 2007 | 10:34 PM
ambainb's Avatar
Car: 86 iroc
Engine: Iron 408 LS3 combo
Transmission: Ram10 T56
Axle/Gears: 3.73 10 bolt :)
Re: performance
well cold air intake is a good idea but your better off building your own instead of spending $200 on one that does the same thing, k&n air cleaners, a high flow mass air flow sensor, high flow 58mm throttle body, a throttle body spacer, not sure but i think you could get a fuel pressure regulator and set the pressure a little higher, you could look up some tpis hints on how to make the tpi flow better, performance chip, headers and a 3in exaust from the cat back will do you good if you dont already have an exaust system. dont forget about diffrent heads, intake manifold and cams. you could have a 3 angle vaulve job done on your stock heads..... there are endless possabilitys it all depends on how much $$$$ you got
Old Oct 9, 2007 | 10:26 PM
Re: performance
thats the problem i have just bought the car so i dont have much money at all. but thanks for the advise
Old Oct 10, 2007 | 05:48 AM
camaro1j's Avatar
Car: 92 Camaro
Engine: 406 sbc
Axle/Gears: 9" ME with 4.56 gears
Re: performance
the cheapest way to make your car faster is get rid of everything in the car you don't need to make it lighter. that includes cleaning all of the dirt off of the undercarriage.
Old Oct 10, 2007 | 10:12 AM
five7kid's Avatar
Posts #'s 2 & 5. That's about the end of the "cheap" things.
I wouldn't call heads "cheap". Or exhaust, although exhaust is needed before you spend any money beyond posts #'s 2 & 5.
I wouldn't spend money on a "performance chip". The better investment is getting the equipment and software to do your own chips. Again, not "cheap", but probably the best way to spend your money. An '89 will be MAF, which doesn't see as much improvement, and isn't as sensitive to other changes, as the '90-'92 speed density systems.
As usual, performance costs money. There aren't any "free" things you can do that will make big differences in performance. There are things that you can do that are "better" than other things, though, like synthetic engine oil, transmission fluid, and gear lube, that should be changed anyway, and while you're at it, spend a little more coin to get something a lot better.
I wouldn't put a K&N air filter on any vehicle I liked. They are nothing more than an expensive way to let more dirt into your engine.
Linson
Oct 24, 2025 02:00 PM
Pac J
May 17, 2020 10:44 AM
jrdturbo
Mar 31, 2016 02:58 PM
armybyrd
Carburetors
Oct 20, 2015 03:57 AM
SRKLEGIN
Interior Parts Wanted
Oct 12, 2015 07:28 AM
