vualve cover ??
Old Oct 9, 2007 | 07:35 AM
86V8Z28Camaro's Avatar
Car: 86' Z28 Camaro
Engine: 350 holly 650cfm carb
Axle/Gears: 3:73 posi
vualve cover ??
i have my sock vauvle covers on but an after market air filter. when i hit the gas it smells like burnin oil.i never put a breather cap on it. i left the lil stock 90 degree angle hose that went into the stock air filter it but i didn't block it off its just open.. could that be my answer to the smell?? please help. (the vauvle cover gaskets are kinda new.)
Old Oct 9, 2007 | 08:00 AM
TexasSilhouette's Avatar
Car: 1991 TransAm GTA 350
Engine: 350 SBC TPI
Re: vualve cover ??
Crankcase gases are vented out the breather hose under hard acceleration. During regular driving the PCV system scavenges the crankcase with normally clean air entering through the same port. With it diconnected you are allowing dirty air into the crankcase.
Don't block it, the pressure needs to be vented.
Old Oct 9, 2007 | 12:08 PM
Car: 86' Z28 Camaro
Re: vualve cover ??
so dont i just put on the breather cap
Old Oct 9, 2007 | 01:16 PM
ryan91rs's Avatar
Car: 1991 RS, 84 El Camino conquista RIP
Engine: 5.0 (for now)
Transmission: 4L60
Axle/Gears: 2.xx torsen limited slip & 3.42 ope
Re: vualve cover ??
a breather cap is good. If you like it real clean then also wrap the breather with a sweat band athletes use for there arms. Sometimes oil can blow out and get on the valve covers (vualve covers)
my favorite place to get them is pepboys, they seem to have the most (or where ever, just get one and change that dirty oil!)
Pac J
May 17, 2020 10:44 AM
skinny z
Oct 5, 2015 06:23 PM
1Aauto
Sponsored Vendors
Oct 5, 2015 03:14 PM
82xCAMAROxZ28
Sep 27, 2015 12:31 AM
Dragonsys
Sep 25, 2015 03:51 PM
